I got a look at the front brake pads today during a tire rotation. I am concerned because the passenger front side pads are about half the size as the driver sides.
This is the most uneven side to side brake wear I have seen. Is this normal on a 2000 LX Odyssey? Both our Isuzu 4x4 and 89 civic never had uneven wear like this.
I am further concerned about the brakes because the one time I have had to use the ABS braking, the braking distance was pretty sad (found myself with the inlaws pretty far into a intersection from 35mph).
Some more info. 2000 LX Odyssey, purchased 9/1999, 27000 miles, original tires, original brake pads, the brake wear noise tabs are just beginning to touch on the passenger front disc, sight measure of the pads maybe 5mm on drive side & 3mm on passanger side.
Given my pass experience with honda brake pads, I am pretty happy to get over 25K miles out the off front brake pads. But do I have a brake pad dragging problem (passenger side), a brake caliber problem (driver side), or some brake system problem in ABS.
I will be taking the van in for other warranty type work (sliding door again), so I will be asking them about the brake problem.
Is there any service bulletins that I should remind the service about on brakes beside maybe #022300?
Does anyone out there know what an average front brake pad life is about?
And of course if anyone out there knows if uneven side to side brake pad is normal on the Odyssey?
Thanks in advance
BrianB
Thanks in advance
BrianB
