1 - 11 of 11 Posts
2012 EX-L, >128k miles, VCM Tuner, Honda tow pkg.
Item #8 on this diagram. This is for a 2012 but you may want to update to your year.
2016 Touring Elite
If that's EVAP, could it be rerouted somewhere better? Fuel filler neck maybe?
It is supposed to go up in the body/chassis like that. It it supposed to be routed to a clean air space. All vehicles since at least the 80's have/had something like that.
-Charlie
-Charlie
guessing that seal for the vent isn't water tight (looks like foam)
a couple posters mentioned hitting a large puddle and then having to change the EVAP canister.
clearly not an ideal design.
2016 Touring Elite
I believe that hose is mostly a 'reference' port and doesn't generally have any airflow. I think it also works as the 'overflow' if there is an overpressure event in the canister.
Large puddles might have other effects under there, applying a lot of mechanical force to the evap system in other ways. It is generally covered by the plastic shield, but who knows?
-Charlie
Reactions: 2011.2017.odyssey
1 - 11 of 11 Posts
