I have a 2011 Odyssey Touring Elite,
I have read all posts I can here is the problem.
Sitting in the van waiting for somone I prob had the radio on but I don't remember.
First symptom both sliding doors will not open by switch or by pulling on the handle
thought oh heck low battery started the van I was a bit sluggish then it started.
Second Symptom CHeck ABS Light
THird Symptom CHECK VSA Light
Forth Symptom Left door now will open if you trigger it by pulling on the handle
Fifth Symptom Left Door Will not open by using dash button
Sixth Symptom Left door will not open by using the pillar switch
Seventh System nothing will open the right sliding door at all
I'm traveling and this is a major crisis.
I did have an accident back in july (not my fault) hit and run that returned 20 min later. he hit the left side tire and foward but all that work is suposed to have been fixed.
I really need to open the doors and what about the idot lights? Please advise ASAP
Thanks
:huh:
Thanks
:huh:
