I just installed USA Spec PA15-HON2 couple of days ago.
Here is step by step installation for Radio with Navigation.
1. You have to dismount center dash board.
Use trim removal tool. Pry right side of dash board. It will pop it open very easily.
Make sure that your gear shift is in the "N" position for easy removal of the board.
2. Center dash board has 3 clip type cable attached. Remove these clips out. Remember its location for later.
3. Remove glove box- if you need this detail, search in this forum. There are plenty of them here.
4. Back to Center dash board. You will now see Radio.
There is 2 screw attach top portion of radio, you have to remove those 2 screws.
5. This is very tricky part. It took me a while to figure out. You have to remove radio unit. But it won't free easily. There are two clips or some kind of joint thingy. You have force it out. But don't force with too hard. You will break it. Use trim removal tool to pry little by little. With Patience, radio will come out.
6. Back of the radio unit, you will see white 14 pin connector in the middle. That is what you need to take it out.
7. Use supplied cable connector to hook up radio unit.
8. From same cable, remove sticker "Remove when use." And use that connector to hook up with connector that it used to be attached to radio unit.
9. Connect the other end of cable to adaptor. And Use IPod connector cable to connect your iPhone or IPod to see it is working.
10. If everything is working order, disconnect iPod connector cable from adaptor.
This is time for cable management. You can use empty space behind radio unit to bring cable down to glove box
11. Put the radio back in.
Then Screw back in.
12. Reconnect USA spec adaptor and find the place to attach adaptor.
I put mine as picture showing. I used double side tape. Some use screw to secure it.
It's all up to you.
13. U-la-la. You are almost done!!!
If you want your iPod connecting cable thru glove box, you have to drill hole.
I didn't do that, I am using proclaim to mount my iphone so my cable is coming from bottom of glove box.
Put glove box back in.
Put Center dash back in.
Job Well Done.
Enjoy your new gadget.
http://img.blog.yahoo.co.kr/ybi/1/d7/7f/ohgom/folder/3417232/img_3417232_1371600_18?1305079211.jpg
I love my new toy!!!!!
I hope this help. All together, it took about 30 min. Very easy job!!!
