1 - 6 of 6 Posts
Do you guys think I can still use my 1.5 ton jack to lift my 4 thousand pound van? So the van is about 2 tons right? Lets say I lift the front end? The jack is not actually lifting the whole 2 tons in theory yes? Maybe half of that. So is it safe or should I just buy a 2 ton jack? Please no negative comments I suck at the laws of physics.
The Ody weighs about 2.2 tons. Over half that is likely on the front, say 1.2 tons. This would be about 80% of the capacity of a 1.5-ton jack.
Your jack would probably handle it. But I would go for a larger jack. First, it would have larger dimensions and so it would be more stable. (You probably use axle stands, but a jack can tip while lifting a car.) Second, a larger jack would require less pumping effort. Some basic quality jacks might also develop leaks when used near their limit.
Yeah its better to be safe than sorry huh? I got one of the harbor freight jacks. I'll get rid of that one and get me the 3 ton jack. No need for two jacks in the garage. Thanks anyway.
Just a side note... when you are at HF, get yourself a pair of jack stands as well. For safety sake, you NEVER want to be under any part of the van when it is only held by a floor jack of any kind. Jackstands are an essential piece of equipment when you work under the vehicle. <public safety message ends here>
Ohh of course. Jack stands I use most definiatly. I also say a little prayer before in go under the danger zone. Freaks me out sometimes.
It depends how much your 1.5 ton jack is worth to you, biggest problem (assuming you are using your jack stands) is blowing the seal and making a mess, no? If you are going to replace it anyway and don't mind the latter, might as well use it while it works.
1 - 6 of 6 Posts
