Hi. I have a 2005 Odyssey with 135,000 miles (original owner, bought new). Recently it nearly stalled and I learned the oil had run dry. It’s never leaked oil before and I’ve always had recommended maintenance. A mechanic replaced a gasket in the spool valve assembly and I thought it was fixed. $800
Soon it displayed the same symptoms (nearly stalled, decreased power) and upon checking the oil it had run out again. I took it to a local Honda dealership and this time they replaced the entire spool valve assembly, the valve cover gaskets the rear and front head plugs, O-rings for camshaft thrust covers, and rear and front UCG set, according to the estimate. That repair was nearly $3000.
soon after that I made about a 5 Hour drive that a friend had to follow me, I was informed that on occasion going up a hill or when giving the vehicle gas a brief puff of smoke would come out of the engine exhaust, but it was not continuous.
Fast forward a month and the vehicle nearly stalled at a red light and again it was out of oil.
I took it to the Honda dealership again and they said they couldn’t find a leak and they recommended a 1000 mile consumption test and think that the piston rings are bad. They gave me a ballpark figure that it would take about $4500 to repair the piston rings or they said that I could put a used engine in it and the only one they could find had 120,000 miles and would cost over $5000 to install. That’s only 15,000 fewer miles than the engine it has.
They didn’t comment upon how they checked for leaks. They didn’t say anything about a dry or wet compression test or a leak down test so I’m not sure how they determine that it isn’t leaking and that they feel the piston rings are bad.
I was really hoping I can take this vehicle to about 200,000 miles. My sister has an 07 Odyssey and it has 200,000 miles and they’ve never had a problem with an oil leak. I have never let the vehicle run hot or had any major problems with it and have always done recommended maintenance.
Any recommendations on if it is worth rebuilding/replacing the piston rings or if that is cost prohibitive should I just keep adding oil and run the vehicle until it dies? Any advice appreciated…
Lordy I hate car payments!
