I'm the owner of a 2008 Honda Odyssey Touring with 158k. This Sunday, I will be adjusting my valves. Everything is pretty straightforward. I've been looking at this video.
The brother is very thorough and knowledgeable. But the rear valve cover is a problem. However, I found someone who says that the easiest way to remove the rear valve cover is to take off the harness cover from the wire harness. It allows you to move the harness out of the way so a person can easily remove the rear valve cover. Here is the video.
Has anyone tried to remove the harness cover from the wire harness? I've looked in our forum, but I could not find anything. Here is an image of the engine harness.
I will attempt to remove the wire harness from the harness cover this Sunday. If anyone has any tips, I'm open to hearing it.
