Thank you very muchNo to neutral. Your engine will turn quite readily in P, as it does when you start it up and just before you turn it off.
There are two of them. There is one behind the egr valve I the front and one in a similar location in the back under the VVT/vtec area. I changed mine because they were leaking.Is there only one camshaft cover seal or two? If there are 2 of them, where is the location of the other one?
Thank you
No, you do can leave it in park.One more question regarding Valve adjustment;
When I want to manually turn the engine from the passenger side with a long wrench in order to get the valves on each cylinder adjusted, does the gear shifter on the car need to be in neutral position?
Any other recommendations in respect to the valve adjustment is greatly appreciated.
Thank you
Here is my cheat sheet. 3 steps means go around the bolts at least three times before finishing them off.Speaking of Torque wrench and torque specs.
There are many different torque specs and patterns on Honda forums about the Valve cover and Intake manifold / Plenum bolts.
I appreciate if some one who did this most recently would tell me the pattern and torque specs on the Valve cover and also on the intake manifold plenum cover bolts.
Thank you very much
Excellent,Here is my cheat sheet. 3 steps means go around the bolts at least three times before finishing them off.![]()
Sent from my moto g(7) power using Tapatalk
This camshaft cover was part of my nightmare once. I tried to remove it because the seal was also leaking, and in my haste and foolishness, I pried it a bit too hard and the cover broke into two. btw, it didn't take a lot of force before it broke into two pieces. 😭There are two of them. There is one behind the egr valve I the front and one in a similar location in the back under the VVT/vtec area. I changed mine because they were leaking.
Look on any dealership's website that offers Honda OEM parts at a discount. Some charge a service fee, others charge varying amounts of sometimes more expensive postage.Good afternoon,
I have a 2007 Odyssey EX-L with 203K miles on it. I think it is time to replace the Valve cover Gaskets. I looked at several threads in this forum but did not exactly found the answer to my questions. My first question is;
1- In respect to the parts needed for this job is this Kit all I need?
Or do I need to replace more parts?
2- I hared it is a pain to get to the rear valve cover at the firewall, any suggestions to make it easier?
- If I want the Original Honda parts, any one has the part number? The Honda catalog is very confusing and does not exactly say in detail which parts are included in the package and for instance only for the front side it asks $185 and the same for the firewall side?!
Any suggestions greatly appreciated.
Thank you
The Victor Reinz kit for a 2007 Ex-L is about $15, plus a few dollars shipping, on rockauto.com. I have always used Permatex silicone sealants from the local auto parts store. I have never had issues with any of these products. Be sure to get an oil and gas resistant (silicone) sealant for valve cover gaskets.The Mahle and Victor/Reinz gaskets are my go-to gaskets. In most cases they are identical to the OE gaskets from Honda. I would bet my lunch money that's who makes them but I can't prove it. That's how identical they are. High quality stuff at a fraction of the cost. In my opinion, as Aisin is to timing belt kits, Mahle is to gaskets.
I just did for my 2005 Odyssey last November. The car no need to be in neutral position. Be very careful when you put rear cover back, don't over tight the screws. I broke one, took a trip to AutoZone, bought tools to remove the broken screw. Make sure the spark plug tubes are alignment with robber booth. I made mistake first time, caused engine oil leaking, then do it again. Can't see it, 2nd time I use finger to make sure.One more question regarding Valve adjustment;
Thank you
I used a little motor oil on the under side of the seal to help them slip over.Also make sure you guide the spark plug tube seals to the outside of the tubes. They can easily get pinched and ripped. Do the front first so you can see how to guide them on properly. This is the hardest part of the job to get right IMO. It easiest to screw up and have to redo it completely.
Hello, There it’s going to be fun DIY but you can do it, 1st of all give yourself a favorite go to your nearest Honda dealership to the part department and they will look for all the gaskets and seal you need they are very helpful just tell them you tech friend is doing the job and that you want to get all the part he needs and they will help you the parts are not that expensive they should be no more than 200 for everything, the reason you need to use OE because the other brands don’t seal properly and they will leak oil right after you have done all the work, good luck and let me know how it goes. The best thing is to enjoy working on you ride if you don’t like getting dirty just pay a good mechanic shop to do it for you.Good afternoon,
Thank you
You may need also throttle body gasket!Good afternoon,
Thank you
