Good morning all,
2015 EX-L with 56k miles. I’ve been doing a one time drain+fill at every oil change (~7k miles) and used Honda ATF. After reading a lot here about Maxlife ATF, decided to switch and did one drain+fill with the new ATF.
observations: smell of Maxlife if much stronger (doesn’t bother me) but I noticed that the shifting from first to second gear is a bit jumpy/jerky; can definitely feel it “push forward”. All other gear shifting is smooth. Usually, this happens until it is warming up and then it seems smoother but before Maxlife it did not behave like this.
I wonder if you have experienced something similar when switching to Maxlife? Should I try to do one or two more D+F to get more Maxlife in the system ?
Thanks for your thoughts.
