1 - 9 of 9 Posts
2011 Odyssey Touring Elite 215K Miles.
This only happens in the morning when it is cold. The van starts up fine, but when I shift into gear (either reserve or drive) the van shudders and engine will die or the RPMs drop to about 500 then return to normal. Once I get the van into gear without the engine dying, I will not have an issue with the van the rest of the day.
I replaced the throttle body in mid December, that has helped some.
Any thoughts on what could be causing this issue?
Thanks
2006 Honda Odyssey (EX)
Have you done an idle relearn with a scan tool?
2007 Odyssey EX-L
Any codes? I would check for a potential vacuum leak somewhere.
What are your trim numbers?
Discussion Starter · #9 ·
The drop is when I put it in reserve and the spike is when I put it in drive after being in reverse.
Black Rectangle Slope Font Line
Slope Rectangle Plot Font Parallel
1 - 9 of 9 Posts
