I just changed out the VSS sensor because the speedometer, cruise control and check engine light came on. Now the speedometer works and the cruise works -best I can tell but the car will not go over 30 mph or so and will not go out of second gear. It also will not rev past 3000 rpm or so when in neutral. It is like it has a rev limiter on it. I've been reading about safe mode on some other threads and websites but have not found what causes it. I'm going to pull the codes today when I get an obd 2 reader. found out where the plug is on this site-thanks, I have checked and double checked all sensor connections. I think this may be unrelated to the vss sensor replacement, but it seems unusual that it would happen right after I replaced it. Any help would be greatly appreciated!
Thanks,
Tim
Thanks,
Tim
