1 - 8 of 8 Posts
Despite what the Panasonic EXL-RES DVD demonstrator disc says, you CAN play recordable CDROMs in the DVD drive. I tried several makes of CDR and some CDRW media, all failed.
I then looked around on the web, and found some text suggesting that CDRW's from different manufacturers might work better or worse(ok, they can't really work worse!).
I stumbled across a CDRW from Imation(3M), at least I think thats it. Its been floating around the computer room for years now, and has no identifying marks.
I used Nero to build myself a videoCD from a sample of video I found on the web. Loaded it into the DVD drive of the van, and much to my surprise, it worked just fine! Good quality video, at least good enough for a 7" diagonal screen.
Now its time for a full-length feature!
Most DVD Players have single laser pickup. Therefore, they cannot read the Gold CDRs. On a single laser pickup, a blue/green CDR will work - not the Gold ones. That is why the imation works.
There used to be a compatibility list maintained in the newsgroups that provided compatibility details between media and DVD players. [Perhaps a search in Google will uncover it?]
A word of caution, just because it plays CDR media does not guarantee it will play CD-RW.
Most CD-RWs are Blue/Green and may work.
If you burn a VCD, try VCD 2.0
Hope this helps.
Actually, I found that page you refer to. It does not have data for Honda's DVD, so I guessed it was similar to the Panasonic units. They simply will not play CDRs, from what I can tell there.
I'll try the blue green CDR's. I have about 80 of them from long ago, and assumed they wouldn't work.
The CDRW that did work is silver in appearance. I've never seen a non-silver CDRW.
Nero worked fine for the VCD I produced. I'll experiment some more....
Yes, you are right, CD-RWs are silver. It must have skipped my mind.
Thanks for the correction.
BTW, my choice would also be to use NERO to burn the VCD.
[This message has been edited by starlight (edited 03-08-2002).]
I just picked up Memorex and Imation CDRW's, and will be trying them out in the van for both audio and video use in the next few days.
I expect to try out video formats beyond VCD as well.
Thanks for the links!
G
Hi Superdad,
I would be very interested in the results of your experimentation as I too have been struggling with trying to burn some VCDs that my kids like to watch. In my case, Rugrats, Veggie Tales, and anything Disney.
Regards,
1 - 8 of 8 Posts
