1 - 2 of 2 Posts
I had a Odyssey 04 EX-L, I DIY a Viper 5701 about half-way and I am stuck. Does anyone know how to wire a #775 relay for door trigger and domelight supervision ?
Had anyone find a tachometer wire inside? I found a wire on top of master cylinder and don't want to run the wire pass a firewall.
Also, do you think the power lock/unlock key are locate on the passenger side or driver door? I think I found both side but it only unlock and not lock. :huh:
Thanks in advance.
Thang
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| SECOND IGNITION|yellow |+ |ignition harness |
| ACCESSORY|white/black |+ |ignition harness |
| POWER LOCK|black/white |- |green 6-pin plug *1 |
| POWER UNLOCK|green/red |- |green 6-pin plug *1 |
| LOCK MOTOR|white/red | |green 10-pin plug *1 |
| UNLOCK MOTOR|lt. green/red | |green 10-pin plug *1 |
| DISARM DEFEAT|lt. green/red | |green 14-pin plug *1 |
| PARKING LIGHTS +|red/black | |10-pin plug *1 |
| HEADLIGHTS|blue/red |- |steering column |
| DOOR TRIGGER|black/white |- |domelight on/off switch |
| DOME SUPERVISION|lt. green |- |domelight on/off switch |
| TRUNK/HATCH PIN|tied in with door | | |
| HOOD PIN|yellow/red |- |right of steering column |
|TRNK/HTCH RELEASE|*4 | | |
| FCTRY ALARM ARM| | | |
|FCTRY ALRM DISARM|blue |- |DDM in driver door |
| TACHOMETER|blue | |above the brake master *2 |
| SPEED SENSE|blue/white | |PCM *3 |
| BRAKE WIRE|white/black |+ |brake pedal switch |
| HORN TRIGGER|lt. green/blue |- |steering column |
| WIPERS|blue and blue/yellow|- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |drivers window motor |
| RF WINDOW UP/DN|blu/wht - blu/yel |A |RF window switch |
| LR WINDOW UP/DN|grn/red - grn/yel |A |LR window switch |
| RR WINDOW UP/DN|red/blu - red/yel |A |RR window switch |
| RADIO 12V|white/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|white/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - brn/wht | |radio |
| RR SPEAKER|red/yel - brn/wht | |radio |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555H or 555U. *1 The plug is located at the bottom of the fuse box. *2 In a 2-pin test connector. *3 The PCM is located in the center console. The speed sense is located in a 32-pin plug. *4 To open and close the power sliding door with a single channel see directfax document #1085.
1 - 2 of 2 Posts
