Hi guys, I have a honda odyssey 2005 EXL. Recently I got an error for the rocker arm actuator, so I replaced the whole rocker arm actuator. I drove around 50-60miles no problem and then I turned off the car for the first time after fixing it. After an hour or so when I start again the vsa and check engine light is on and my car is going in limp mode. When I press the gas paddle the engine rpm doesn’t change. But after I let the car warm up for 10 mins and turn off the car and turn it back on, the vsa light turns off and I could erase the code and drive my car with no issue. And same error comes back when i turn off the car for 8-10 hours or so. I have no clue why that happens. I changed all the oxygen sensor and throttle body and ECU. The check engine light shows the Map sensor low,EVAP sensor low, throttle position sensor low, P0641 voltage reference A circuit open. I suspect that this P0641 code has something to do with it because all the sensor are showing low but this code shoes the circuit open. I also checked the connectors and harness but everything seems fine. Can anyone help me with it?
