The vehicle is a 2008 Honda Ody. It has 210K. Due to a new, slight noise and pull in the front-end, I decided to do some major work this weekend (overkill, but after no problems and so many miles, I thought it would be good prevention). But now I have VSA, ABS and brake lights on and a lot of confusion about it.
Work done: control arms, inner and outer tie rods, sway bar bushing, sway bar links, struts, shocks, cv axles. Both sides.
Needs done: alignment. It is bad. I tried measuring lengths of tie rods, but it visually is toe in.
I left the battery connected during the repairs. I ran the vehicle in the air prior to disassembly and manually turned off the VSA. I did not turn it back on. I disconnected the ABS sensors on both sides when pulling everything apart. On the drivers side, I attempted to carefully remove it from the hub, but gave up. My method was slightly pry, then attempt to tap it out from the back side. It did not appear to move or get damaged. This may be the source of the ABS light and I may need a new sensor of this side. Thoughts, other than STUPID to try to pull it out? Can this also be the cause of the brake light? Is there a way to use the onboard system to give me a code to tell me what it thinks is at fault?
The VSA is odd. Could it be just from the bad alignment and bad ABS sensor? According to this link, it would seem it is uncommon for something to go bad related to VSA: The Honda Yellow Triangle Exclamation VSA Light Just Came On - Here's What To Do | Torque News
Thanks for the help. I am very anxious right now.
