1 - 1 of 1 Posts
After doing some searching, I found out that the voltage drops on start up for a split second to 10.5 then back to 14 when running. I read somewhere that the vsa/abs needs proper voltage on start-up and if it didn't have it it would not let the sliding doors open and the vsa/abs lights would stay on. Could the voltage drop be associated with the ignition? If so, what would be a good starting place for checking what the problem could be?
1 - 1 of 1 Posts
