1 - 2 of 2 Posts
Battery died ony 2012. I was able to jumpstart but now both the abs and vsa warning lights are on and i figure out how to clear them off. Been like this for over a week. Van drives fine
do a hard reset, on the battery take the negative cable off, then the positive (in that order)
touch two cables together (not connected to battery!) for 5-10 seconds, reconnect the positive terminal then the negative.
In that order.
codes should be gone.
or get a Honda specific scanner on there and clear the code.
1 - 2 of 2 Posts
