I need some help from you guys with navigation systems. Apparently, I'm missing something called a Vehicle Speed Pulse (VSP)sensor. It used to detect the speed of the vehicle when it's moving. It's also the thing that switches the Map Guide to the more detail Guidance Map.
It's located on the right side of the engine, under the pink brake fluid and it's near 1 large golden bolt and a 1 blue bolt.
There should be a grey colored harness sticking upwards out something. In my pictures the VSP is supposed to be mounted on the metal plate with 4-5 holes.
I basically need know where the grey harness leads to. Is it a part of the main wire harness in the engine? Or is it a totally separate wire? Here's the pics:
http://nemogira.com/odyssey/VSP/VSP.htm
Thanks in advance,
-Nestor
Thanks in advance,
-Nestor
