I assume you have cut your rain shields and are perhaps concerned about water damage to the speakers.
There has been discussion on the use of rainshields (pro/con) in this forum. I feel their effectiveness is marginal since they do not really seal up the back of the speaker from moisture. (if they did, bass response would be very much compromised, unless you did a custom fiberglass enclosure in the door) Anyway, my Ody has cut rain sheilds and I have not fabricated anything else to protect my investment.
I've installed lots of car stereos and used to live in Boston/Michigan too, where cold harsh winters are common. No problems with door speakers prematurely failing/rusting/etc... but I'm talking aftermarkets made from good materials (poly cones, rubber surrounds, finished baskets). Factory speakers made from paper with textile or foam surrounds are more susceptible to the elements, thus the "shields". Factory speaks that are of these materials always degrade severely over time, regardless of what you do...
To sum up: if you replace your door speaks with quality aftermarket's I wouldn't worry about it. If you are anal, make a new rain sheild, by all means, just be sure to keep the back of the speaker relatively open for the Pioneers and other common 6.5s because otherwise you will compromise bass performance.
Hope this helps.
-Shin John
