1 - 20 of 22 Posts
Hey guys -
I have an '02 Oddy EX-L. Has a 5-speed tranny that's about 2-3 months old (rebuilt). Generally starts, runs, and drives like a champ, 127k miles.
If I'm at about 45-50 MPH cruising, the trans shifts into 5th and the RPM's are right around 1500. The car will chug and stutter at that speed, only at light cruising load. If I give it some gas or ease off it goes away.
First thought was motor mounts, I've visually inspected them when I first got the van and they seem OK, the major ones actually look fairly new. Not sure if the trans is doing something weird there or what.
Also, the trans will "downshift" when going down a hill, it will rev up and coast down, just like driving a manual transmission and downshifting to use engine braking. It's not noticeable on flat ground, just decelerating going downhill.
Threw that out there, not sure if it's related to the main problem. It's getting REALLY annoying.
No check engine light, but I haven't checked for codes yet.
Thanks!
Dale
Hey guys -
Dale
That sure sounds like the EGR valve or EGR port problem.
SB 05-026
When my valve started failing - real noticable at those speeds - it never gave a code.
+1 ^^ Classic EGR symptoms. The engine stumbles because the fuel mixture is too lean because of bad EGR. Stepping on the gas enriches the mixture so the problem goes away.
The downshifting you describe is normal - "Grade Logic" in Honda speak. It should however downshift only if you touch the brake.
Ah! Thank you! I'm researching EGR stuff right now, that DOES sound just like the problem!
THANKS!
Dale
Discussion Starter · #7 ·
There is a Youtube video showing a how-to on cleaning the EGR passages. Also, you can Google and find the EGR TSB's that show how to pull the intake manifold and clean the EGR passages.
Can't wait to tackle this over the weekend, it's driving me NUTS!
Dale
I believe this was the latest version of the TSB dated 2/5/08;
http://home.comcast.net/~jnpsmith07/A05-026.pdf
Okay guys, on repair procedure B in the TSB (the cleaning procudure, procedure A is replacing the EGR Valve), page 7 shows the repair technician using a special drill bit to ream out the EGR main passage port and then a pipe-kit sleeve that you tap into the new larger opening described on page 8. This tool is described on page 2 as EGR Pipe Installation Kit: T/N 07ZAD-P8AA000.
Did anyone do this, looks like it's just opening this port a little larger, but you would need to use this tool and be uber careful not to drill through too far :)
-Roy
Repair B (reaming of port and insertion of teflon pipe) is NOT for your 2002 model.
The TSB states: "REPAIR PROCEDURE B: EGR PORT CLEANING
AND INSTALLATION OF EGR PIPE KIT
NOTE: This procedure is only for 1999–01 Odysseys
thru VIN 2HKRL18..1H586575 not yet repaired
according to S/B 00-009."
Follow Dale's procedure and replace the EGR valve (if faulty) but do NOT perform Repair Procedure B which is drilling the EGR port to make it larger and installing a teflon tube.
I'm curious to know if replacing the EGR valve fixed your issues. I have a 15' Odyssey that chugs around 30-40 MPH, goes in between 2-3 RPMs. I've replaced the spark plugs and it seemed to work for maybe a day and now back to square one. My other thought was timing belt (timing issue) since we are at 103K miles now. Curious on anyone's thoughts before I buy an EGR valve. Thanks all!
Muzzle the VCM...
try dropping the transmission out of lockup, by pushing the button on the side of the shifter, see if that helps.
Don't change parts unless there are codes.
TB service is due soon and does include spark plugs as part of your service.
wont solve the issue you are describing.
Muzzle the VCM...
So you’re saying don’t replace EGR and T
It would be best to create a new thread in the 4th Generation section instead of reviving a 2nd Gen thread for a model that's 13 years older! So many differences between these different motors and transmissions!
Hey guys -
F
Dale
I've had this issue for yearsssss, Changed the egr valve and cleaned egr ports and noticed nearly no difference
also sometimes if going up hill i lose a bit of speed even though maintaining the accelerator at a steady position
I have the same problem too. New EGR, cleaned out passages several times, Also getting random stumble at idle, (valves have been adjusted several times too). Anyone have any advice?
2002 with 245,000 km
1 - 20 of 22 Posts
