I did the same (zoom in). That has a hex head shape and tapers upward ... @white2015 , I'm pretty sure you're right: its the darn rubber thingy that is inside a generic spark plug socket. I've had them fall out (luckily with the socket not over the engine's spark plug tube.)After zooming in
It does not look like a plug.
Maybe a gasket that is inside your spark plug socket.
To hold the plug when it is out of its threads.
Well then, how did they do a compression test? Can they use an adapter that doesn't screw into the spark plug hole threads?I did the same (zoom in). That has a hex head shape and tapers upward ... @white2015 , I'm pretty sure you're right: its the darn rubber thingy that is inside a generic spark plug socket. I've had them fall out (luckily with the socket not over the engine's spark plug tube.)
@bresodyssey , what was the result of all this?
This was my thought process.I guess that while he was installing sparkplugs in the adjacent cyls the rubber plug may have dropped out of the socket and into the hole. I would think he would have realized that when he put the spark plug in the socket to do that cyl, as it wouldn't stay in the socket without that rubber plug. 🤯
The mechanic has the answer, whether he knows it or not.they checked and have all their pieces from their kit
Not if there is a hole in that plug. I would bet that if you crank the engine over now a lot or air comes out of that hole. Does it? Course you don't want to take the chance of it getting sucked in.If compression in that cylinder would blow it out it would have come out long ago.........
those "spring legs" are very weak and don't hold something that's jammed pretty well.just use the spring legs to grab the object and get it out
yes, that could work, if it is the rubber plug. Even crochet hook would "hook" to the rubber...Maybe even use a long lag type bolt that will screw into that rubber plug
that's the best way to determine what do to next. Observe first, scratch your head later.Do you have a boroscope inspection camera?
Funny thing, my magnetic spark plug socket is a bit to strong so it can pull out my extension if I'm not careful... still much better than the rubber insert style. Its also a good idea to hit the spark plug ceramic with just a bit of dielectric grease / silicone lube to allow the spark plug boot to pop out easy the next time.I think it's the rubber inside the spark plug socket (designed to protect the spark plug when you pull it out). Get a spark plug socket with magnetic inside and you won't have this issue again.
Technically it is for grabbing on to the spark plug primarily.(designed to protect the spark plug when you pull it out)
Agreed. My rubber one broke off as they so commonly do while I was in the middle of reinstalling plugs in my old Accord. Luckily, it broke off in a way where if I put the socket back in the cylinder where it broke off in, it would come out with the spark plug, so getting it out wasn't very difficult. I went out that night and bought a magnetic Duralast socket from AutoZone instead. Haven't had an issue with it.Funny thing, my magnetic spark plug socket is a bit to strong so it can pull out my extension if I'm not careful... still much better than the rubber insert style. Its also a good idea to hit the spark plug ceramic with just a bit of dielectric grease / silicone lube to allow the spark plug boot to pop out easy the next time.
-Charlie
I put paper (blue) tape on the tip of extension, so it will be held tightly in the socket.Funny thing, my magnetic spark plug socket is a bit to strong so it can pull out my extension if I'm not careful..
Maybe they did not really do the test.Well then, how did they do a compression test? Can they use an adapter that doesn't screw into the spark plug hole threads?
After the compression test the OP tried to install the spark plugs and found the hole plugged up.
Unless he put his spark plug wrench into that hole BEFORE he put a spark plug in his wrench, I don't understand how that obstruction happened. Still, the helpful suggestions on how to remove, whatever it is, are good.
it will be interesting to see what it is and 'how' and 'when' it happened.
Some info definitely seems to be missing.
Buffalo4
PS: I guess that while he was installing sparkplugs in the adjacent cyls the rubber plug may have dropped out of the socket and into the hole. I would think he would have realized that when he put the spark plug in the socket to do that cyl, as it wouldn't stay in the socket without that rubber plug. 🤯
GEARWRENCH 3/8" Drive 6 Pt. 5/8" x 6" Magnetic Swivel Spark Plug Socket - 80546 $10.88 on Amazon now.Funny thing, my magnetic spark plug socket is a bit to strong so it can pull out my extension if I'm not careful... still much better than the rubber insert style. Its also a good idea to hit the spark plug ceramic with just a bit of dielectric grease / silicone lube to allow the spark plug boot to pop out easy the next time.
-Charlie
