I was removing my passenger front tire to replace the rotor and broke a wheel stud. I removed the castle nut on the end ofthe half shaft but can"t pull off the hub. Do I have to disconnect the a-arm,strut,and tie rod to be able to pull the hub off? It seems like the hub would just slide out after the shaft is pushed in.
