When shall I replace the breaking pads? 3mm or 2mm?
Tags
break pads
1 reading
3.7K views 10 replies 9 participants last post by  phattyduck
Don't rely on the squealer! The metal tab had broken off on one of my rear brakes. When I heard the growl of metal on metal I knew I had to slap on new pads. (One pad wore prematurely fast because a rubber boot on a caliper pin was not seated properly, and the pin stuck.)
I usually go by the separation groove in the middle of the pads, which I usually check spring and fall. If the groove is shallow or nearly gone, time for new pads. No groove- you're overdue!
