1 - 11 of 11 Posts
Hi - I need to confirm that the pass side window motor is bad. Does anybody know which wire I can jumper with 12V? Do I just ground to the body of the motor? The wiring diagram is confusing to me. Thanks,
MT
Do you have the motor out already?
Here is an image for the test.
No Problem.
The usual failure mode of these is the window will drop into the door and will not come back up. There are a lot of videos about replacing it all. Not really an expensive part either if I recall.
Discussion Starter #8
Thanks, egads. It's my Dad's van and I don't know much at this point. I'll get the door panel off and see what's what,
MT
Discussion Starter #9
Well the window motor works just fine, up and down, when I jumper it. I see a small relay tucked in near the plug-in for the pass switch. I guess I should test that next,
MT
Discussion Starter #10
Closing the loop on this, it was just a bad window switch on the passenger side. I got lucky. All works now,
MT
1 - 11 of 11 Posts
