I cannot be certain it will work. I know some parts are interchangable between Hondas. For example, CIVIC gauges, euro dash kits and even strut bars will fit CRV vehicles.
I would look at this picture, make sure the RPM and door status lights are in the same location, including dimmer control.
The above picture is from a V6 vehicle. Below is a picture of a cluster from a 4 CYLINDER. Although they look the same, they are different. The gauges are actually manufactured by FORD? which is discouraging.
If the RPM does not match up or if the speedo does not match up, you may or may not want to continue with the project.
Here to help
