1 - 15 of 15 Posts
Its about 1/2" of, the end piece is soft like a vac line, it comes thru the firewall near the top driverside corner of the transmition, and is shaped to bend down (I am bending it about 90 deg). Wherse it go?
Looks like a drain tube. Where is attached onyhr other side?
Sent from my SM-N960U using Tapatalk
Its about 1/2" od, the end piece is soft like a vac line, it comes thru the firewall near the top driverside corner of the transmition, and is shaped to bend down (I am bending it about 90 deg). Wherse it go?
The firewall
Maybe take a shot further back and point to it or use the photo editor to point at it. Kinda look the hose that attaches to the intake buy not sure on the odyssey.
Discussion Starter #8
What year is that odyssey? I have a 2006 and it doesn't look anything like that.
Looks like a drain for the AC OR sunroof. If it's zipped tied then maybe someone else thought it needed to be becuae the zip tie is to far back to holding whatever it may have been on if anything.
1 - 15 of 15 Posts
