I'd have to agree with HondaUpNorth, it's very likely that the wheels won't clear the calipers.
I have a 2008 TL typeS with the brembo brakes, and honestly, i wouldn't like them on the van. They generate a massive amount of brake dust, also the replacement pads i believe run in the $250 dollar range. It's true you can go with cheaper pads, but I just don't think it's worth the trouble on the ody.
I swapped to the magnum drilled rotors and ceramic pads and am very happy, I get tons of braking and little dust, I can "late brake" for stops and apexes like I am driving a sporty car! Recommend - also solved noise issue with grinding. so far so good no warping. ceramic as I understand it also has less heat - less warping, wear on rotors.
