1 - 2 of 2 Posts
I had to replace the window regulator in my 06 Odyssey on the left read window and when I went to purchase the part it was sold as the motor only. Since that is the only thing that seemed to be wrong, I tried replacing just the motor. Well the whole assembly is not available, the part has been discontinued. After tons of research and visiting several auto stores I finally came across one that said it would work. The problem is, on the broken regulator there is a some kind of mechanism and I’m not sure what its purpose can be. Otherwise, the final part that I found is a perfect fit. The piece is welded on so taking it off and putting it on the new one probably wouldn’t work. I have included some pictures for reference.
152725
152726
Have you considered going to a pick n' pull yard? My favorite yard hasn't had many 3rd gens for a while- but now has 4. You could remove just the part you need.
1 - 2 of 2 Posts
