How do I remove these? My hood was painted and they were not put in fully. How are they supposed to go in?
I just replaced one of mine.
Remove the black rubber hose from each nozzle from under the hood, and there are two tabs on each nozzle that need to be squeezed together. Use a pair of needle nose pliers to squeeze them, then push them out towards the top (exterior) of the hood.
Should take no more than a minute to replace each one.
do I just pull off the rubber hose? Mine has a 5-10mm rubber cover on the under side of the hood
Thanks
I see what you mean
Thank you hockeyman. The hose and nozzle push up through the hood. The big black cover was a boot. One of mine is missing a boot and the clip is weak so the nozzle tilts. One is fixed though.
Always something-I just noticed a coolant leak at top of radiator just below the cap. I will ask if JB weld would work.
Thanks for being on the forum
