Just bought a 2005 Odyssey Touring and first thing kids wanted to do was watch a DVD with the wireless headphones. We are having issues hearing anything out of them though. The headphones are turned on, and I can hear static like it's on, but I can't hear anything from the movie. Volume is turned up all the way too. Any ideas?
Btw I am a newbie and just figured out how to search forums so I apologize if this thread has been discussed. Trying to find my answer now but if anyone has an answer it would be appreciated.
Guess I'll just close this out. My issue wasn't with just my wireless headphones, but also my headphone jacks. It wasn't with just the DVD, it was with anything from the RES. After reading forums about radio replacements, cable replacements, and battery terminal disconnects, I pulled the 10A fuse for the radio overnight. The next day wireless headphones were back to working. Looks like a known issue with the radio reseting itself. This is a lot faster than pulling battery terminals off, and less expensive than replacing the radio (especially since my 05 is out of warrenty period). Also, you only have to enter the radio code when you put the fuse back in. With the battery terminal trick, you may have to reset the power doors, tailgate and who knows what else. Just an FYI for any "NEWBIE" who runs into this.
I saw your post about removing the radio fuse to re-energize the wireless signal for the Honda DVD player. You mentioned that you specifically set the fuse out overnight - was there a particular reason for this? I am having the same problem that you described - I pulled the fuse but replaced it a few minutes later and it did not work but want to understand if time does make a difference?
Sometimes the system needs to be reset, and not leaving it unpowered long enough does not reset it. I'm not sure what the exact time it takes without power to reset the RSE, but we usually recommend unplugging the system for several hours "just to make sure."
The idea of removing the fuse is an interesting one. Normally, people always unplug the battery - but that has the effect of deleting memory settings on more than just the RSE!
Related Threads
Honda Odyssey Forum
1.1M posts
412K members
Since 2000
Odyclub community is the #1 forum to discuss all things Honda Odyssey: minivans, safety, service maintenance, mods, and more.
