1 - 20 of 27 Posts
Critter wanted!
At least your diagnostic was spot on. (y)
Just wish I could find the other end of that harness.
Why do you need the other end? That chewed up end is terminated into that big Gray plug, is it not?
Hey may just want to replace the whole wire, from the other end to there.
Well for 40 bucks I thought it would be worth it to just put a new one in. Were you going to suggest repairing the cable?
Exactly, get your replacement whether it is new or from junkyard then cut off the end you don't need. Then attach it to the chewed up end. Problem solved.
I could see that if it is complicated and LONG line, but from the look of the diagram, it does not look TOO bad - I say locate the other end and see how easy it looks like in terms of removal and if it looks complicate, fix the cable, if not, try to get one from salvage since you already know how to get to the other end.
1 - 20 of 27 Posts
