Okay, I actually know what PCV valve is-- at least I used to... It is a positive crankcase ventilation valve. They used to be hooked to a vacuum line to evacuate blow-by and general undesirable gasses floating around in a crankcase. They take the exhaust gas and let a hose suck it back into the intake manifold, where the junk gets burned in the combustion chamber. And they are one way valves where things cannot flow back into the crankcase through them...
Okay, simple enough. Only today I learned that the PCV valve on my Odyssey has no vacuum line attached? Really? How exactly does that work?
I was wanting to see if the slight oil leak I have might be caused by a PCV issue. So little of a leak that mostly it seems to be that I smell oil and see a tiny bit of oil smoke around the engine when I turn it off, but there is no oil dripping, or worst case, just a tiny drip.
Interestingly, the oil smoke seems to be coming up from the front side of the engine, down below the PCV location.
I looked up where to find the PCV (down by the oil dipstick). I unbolted the old one-- this once I realized the reason I couldn't find it based on the vacuum hose because it apparently HAS no hose, and tried to remove it. Well, it was a bit tight, or otherwise stuck. A slight tap made the thing disappear, almost like a rather mean magic trick...
I'm sort of stumped-- it slipped forward and went "plink" and I cannot find it anywhere. I wanted to see the condition of the thing before I replaced it. It is not under the car. It is not inside the fan housing. My best guess is it went under the radiator or else under the engine (etc.) in a supporting member of the frame.
So all I could do was replace the part. I got an OEM PVC valve and inspected it-- Okay so there is no hose, and apparently there is no "one way" action, as I could pass air through it both directions.
I actually bought it at a local parts store, but the box contained what appears to be an OEM Honda PCV in a sealed Honda plastic package. Could it be a defect? Sure, but that seems unlikely.
It seems much more likely that I'm getting old and the world is changing too fast, but I'd sure like a little more information about why a PCV apparently no longer burns off the offending gasses or is actually a positive valve at all.
Does anybody have some information to shed some light? I cannot check the leak right now because I'm still fighting with a different issue, but once we're running again, I'm awfully anxious to see if this improves things a bit...
