1 - 20 of 25 Posts
drslums
I have an 07 with 163K miles on it. There were no leaking until about 2 weeks ago I found oil spot at the parking place. I went under the van then I see oil under the transmission (it's oil with yellow color and smell not transmission fluid with pink color). I wiped it off then took the PCV valve out and clean with carburetor spraying can. A lot of black stuff getting out of the PCV valve and the hole where I took the valve out. I put the PVC valve back again then the leaking event worst. I've lost about haft a quart over the last 2 weeks. One thing I can see is if I clean everything and leave the van over night there is no visible leak but if I drive the car for about 50 mile then I can see the oil drip when I stop. Also, I can smell the oil burning (maybe the oil leaking out then get burn by the exhaust line). I took the PCV valve out again then I can see oil at the bottom of it. Is that normal when I found oil at PCV valve?
What do you guy think?
1. Is that the PCV valve symptom? Should I change it because after the cleaning, I still can hear the clicking sound when shake it.
2. If the seal gone bad, will the oil leak when park? I asked so because if the oil level is below the seal then it will not leak event if the seal gone bad.
3. What is the worst case if I that the rear main case seal leak and I dont fix it? I know that it's an expensive fix but I dont wanna pay like more than $1K for the van. How about just keep adding oil?
Thank you.
1. It could be but based on the age of the engine, it probably is not. If the PCV will allow air passage, that isn't it. It is most likely the seal.
2. When parked, you will only see drippage from whatever has collected in the transmission bell housing. With this oil being so thin, it will drool pretty quickly out of the engine. The seal is above the oil an only gets wet inside the engine when the engine is running.
3. If you don't fix it, the seal will continue to deteriorate and let oil past when the engine is running. You will need to manage the lost oil constantly. The same thing happened on my 2000 Accord where it the seal let go at 110,000 ish miles. The only fix was to separate the engine/transmission and replace it. My Accord was spilling a lot of oil all at once. My wife left in the car and I went into the garage and saw a lot of oil on the floor. A very sick feeling.
I can assure you that it's most likely the rear main seal. There is an inspection plate (black in color with two 10mm bolts). You should be able to see with a flashlight to verify.
I did my own back in Nov. '13 with roughly 136-140k miles on the odometer.
I took the black cover off which is hold by the 2 of 10mm bolts and saw the oil there but no oil at the transmission side.
What did you do with your car? How much does it cost? Do you think change to heavier oil is a good idea?
i removed the subframe, and then transmission in order to replace the rear main seal....However,did so as part of replacing the torque converter due to a shudder condition. I've since, removed the trans yet again to rebuild it due to harsh engagement while going to "R" from "P" or "N".
I'd suggest against the heavier oil. The engine is best suited to use the 5W-20.
+1 to stay with the recommended oil viscosity.
Try an oil seal additive. I don't normally suggest such stuff, but it just might save you a grand.
Dave
I changed the PCV valve but the oil still leak so I came to the dealer today. They said it's oil pan crack. How is it possible (like did I hit something etc)? Anyway they want $414 for fixing it now or $120 for the check up only so I told them go a head and change it. My calculation is if I bring it to other mechanic then it might be more than haft of $414 plus $120 that I have to pay the dealer anyway so I will save less than $100 (about 70 to 80) if do it at non-authorized dealer (not worth all of the headache if any) so I told them to change it.
I search all over the forum and I still inclined to the rear main seal problem. My next question is:
1. How often you see the oil pan crack on a 3rd generation? What is the most frequent reason?
2. What will happen if the oil still leak and this time they find out that the rear main seal is the main reason? Will they deduct the cost of the oil pan to the rear main seal?
Thank you.
Hi Drslums... I assume they gave you your oilpan back.. if so, do you mind taking some photos of the area they indicated is cracked and post them?...
Thank you.
Good idea to ask for the return of the old oil pan so you can confirm that it is cracked. IIRC, this is very rare.
If it doesn't look cracked and if the leak is still there, you will have a good case to get a credit for the oil pan replacement toward replacing the rear main seal.
In the meantime, I will keep my fingers crossed that replacing the oil pan will fix the leak.
Dave
Quick q. Where is the black cover located to peek at the rear seal? I wanted to check mine too. I have leak still and supposedly my seal was replaced during trans job. Just want to make sure. Thanks.
Discussion starter · #12 ·
The black plate is the one between the transmission and the engine block. You can take 2 of 10mm off then the plate will fall off easy.
I take the van back. They said they through the oil pan away so they cannot give it to me even if I called at 11AM and they said the part (oil pan) were not there yet and when they called me back again at 2PM and said the van were ready. At that time I asked for the old oil pan and they said they through it away.
More importanly: The van still leaking. What should I do now?
What state do you live in? It differs by state as shown by these 2 examples:
Michigan Law:
Return Replaced Parts
Along with an itemized final invoice, the law entitles the customer to all replaced parts.
If the customer neither asks for a replaced part nor authorizes you to throw it away – in other words, he or she does not mention the part – you must keep it for two business days after the vehicle is picked up.
California Law
Return of old Parts
When you sign the written estimate or work order, you can ask the shop to return to you any parts that were replaced. The shop is required by law to return the parts to you only if you ask for them before the work is done.
That said, it seems a little strange that even if they did throw the part away between 11 AM and 2 PM, one might assume (dangerous, I know) that the part would still be on the premises. You could do a little investigating and find out when their dumpsters are emptied. If they aren't normally emptied between between 11 AM and 2 PM on the weekday of the incident, the fact that they wouldn't give it back to you because they "threw it away" is very suspicious.
Have you spoken to a manager yet? That would certainly be my next step.
You will tell them
1) you brought the car to the dealership to fix an oil leaking problem
2) the dealership diagnosed the leaking problem and worked on the leak. The repair costs you $414.
3) after the first repair, the van is still leaking, so the first repair was not fixing the problem.
Please fix the leak again and apply the $414 credit to the 2nd repair.
I couldn't find the Oklahoma law regarding the return of replaced parts. You could call the number for your state's Consumer Protection office and ask them how replaced parts are supposed to be dealt with.
https://www.oag.ok.gov/oagweb.nsf/Consumer!OpenPage
As far as the leak, txn has laid out the basic process. I'll add that if you don't get satisfaction from the service rep, escalate the issue to the service manager, then the general manager, then the regional manager, etc. Once you start talking with someone at the management level, you might want to mention that you've contacted the Consumer Protection department but haven't filed a complaint...yet.
***snip***
***snip***
They couldn't have retrieved it from the dumpster?! I sense an unscrupulous dealer story evolving here.
Dave
I have/had a very light RMS leak, and was considering doing the seal change myself as the dealer/mechanic wanted around $1200 to $1400 to replace the seal :(
So I gave AT-205 a shot.. And its been in my in my crankcase for about 1 month now since the last oil change, and just about a week ago, I cleaned the area on the bottom of the bell housing/motor where the oil would drip slowly out, and it appears to have stopped..
Keeping my fingers crossed!.
Amazon.com: ATP AT-205 Re-Seal Stops Leaks, 8 Ounce Bottle: Automotive
Are you using the right viscosity of engine oil? I have seen a few RMS leak because the owner put in 5w20 oil instead the recommended 5w30 on a Honda engine?
5W20 is the correct oil.
The pain with the rear main seal leak (at least for our van) was that it dripped right onto the exhaust and smoked a lot - since it's the wife and kids daily driver, that was not a workable situation - I threw in the towel and had the thing replaced - sucks paying $800 for a $15 part, but the leak was fixed.
1 - 20 of 25 Posts
