I'm in the process of replacing the PCV valve on our 2008 EX-L and it broke off during the attempted removal. What's the best way to get the rest out?
Actually, I was able to get the metal spring out! But thanks for the reassurance. ;-)There is ONE metallic part
Yeah, I tried a shop vac, but it didn't get anything... I duct taped a piece of flexible clear tubing on the shop vac hose, to try to fish around inside the PCV cavity, but nothing came out (other than a bit of oil). :-(I got mine out too when this happened. The shop vac worked wonders.
Yeah, that sounds like the right approach. I know for next time! :tongue:Just replace this in my 05 with 166k miles, it was tough getting out but it did not break. It was totally gunked up, no noise when shaking it and a thick layer of stuff on the outside. Got it out by twisting it back and forth until I got a gap of about 1/8 inch then used a flat screw driver to slowly twist to increase the gap, it came out easy after that.
