Hi everyone,
Thanks to 0dyfamily and some folks at the Torque forum I think I got the PID values correct to display transmission temperature on the Odyssey. I'm hoping some folks can try this out and let me know how it works. It seems to behave exactly as I expected from the other vehicles I've monitored transmission temps. A short 5-mile drive in 70° weather got it to 115° F. Applying power in drive with the brake depressed caused the temperature to rapidly rise and hold when I let off. Driving around it seemed to level off around 175° on the rural highways of northern Connecticut. I'll be adding a transmission cooler in the next week to prep for towing, and I would expect these values to decline significantly. That is, of course, IF the PID is setup correctly for transmission temperature.
Here's what I got:
Here's what I got:
Mode and PID: 222201 Name: Transmission Temp Minimum: -40 Maximum: 300 Scale factor: x1 Unit type: F Equation: AA*(9/5)-40 OBD Header: 18DA1DF1 Any takers? Let me know how it works out for you! |
