1 - 10 of 10 Posts
Pbennett45
Hey all,
Just did the rear pads and rotors on my 2018 Odyssey. I had done my research, so wasn't too thrown off by the electronic E brake actuator... So just wanted to 1) document the process... 2) confirm with the forum I did everything right on a few areas that I found contradictory info on the interwebs (go figure)
For general overview... The electronic EBrake as well as (presumably) the collision avoidance system (?) use an electric motor to actuate the rear brakes. Unlike the cable wound rear brakes (that also integrate the parking brake into the disc brake instead of the drum/disc combo deal) you can't just use the 2 or 3 pin tool to wind back the caliper. If you do that you (the internet claims) risk damaging the EBrake motor.
If you have a high end scan tool ($250+, or the real Honda one for waayy more than that) Honda has a maintenance mode to retract the caliper. This is NOT normal OBD commands and the $30 Bluetooth job with the $10 Android app doesn't cut it. Seems auto manufacturers charge a fortune for these companies to have access to the command format for their proprietary command, and that's what you're really paying for- not anything special about the scan tool hardware (can't they price this crap into the car price!?). Someone on another forum mentioned the $60 maxi Bluetooth adapter... My finding on that is that you pay an annual subscription fee on top of that to make it do anything more than normal OBD. Couple hundred was the cheapest non subscription based option I found. (I have as personal hatred of paying subscription fees to use a piece of hardware I already paid for!).
If you don't want to do that... Honda allegedly also lists removing the actuator (the electric motor assembly) as an option. It's two small torx bolts and came off easily. Honda recommends replacing those bolts and an oring... Interwebs are skeptical of the need to do so. I did not bother.
Next is where there's contradictory info floating around. One set of instructions I found said you needed a e11 torx SOCKET to wind back the actuator. However the caliper side on my 2018 Odyssey doesn't need a socket it needs a torx wrench. And a big one.. Bigger than I had.
But I also found instruction that said first turn that until it bottoms out then wind back the piston as normal.
This is where I got confused and deviated.... Once the motor is removed, how is this possibly any different than a cable wound assembly? So I put on the 3 pin adapter and turned gently.. Wound back just fine.. Seems to work....EBrake is fine.. No weird error codes. Seems to me that the "wind back with a torx" step (be it a torx SOCKET or torx wrench) is INSTEAD of using the 3 pin adapter. Once you've removed the motor assembly (the actuator) to not damage the gearing inside that... It seems like it's just the piston on a screw thread and these options both do the same thing from opposite sides?
Anyone disagree? Did I do something dumb? Is the internet just dumb? (Haha, of course it is.. But on this particular point!)
Thanks... Hope something can confirm I did it right and hope the other info helps others.
The electric parking brakes mechanically engage the rear pads using a large gear reduction system. The collision avoidance and ACC cruise control apply the main brakes as needed. Lightly place your foot under the brake pedal, and you can feel the car physically pressing the brake.
It takes no effort to wind the parking brake back. I used an appropriately sized flat-head screwdriver to rotate the splines.
There is no need to wind it back to the original position. Just activate the rear brake a few times after the project is completed.
There are no cables inside the parking brake assembly, it is a massive gear reduction system.
Hrmm.. Score one again for the adviser at the tire shop..haha. he claimed collision avoidance rips through rear brakes because it only used the rear. Glad I ALSO ignored him when he warned me how hard this brake job would be to do on my own because of the electronic EBrake.
Yup.. Guess I wasn't clear. Just wound it back enough to fit the new pads over the rotor like a normal brake job. Thanks for clarifying.
Thanks for the updates!
I did this too when I change rear bakes and rotors, had no issues.
Sent from my iPhone using Tapatalk
I finally replaced my 2018 Honda Odyssey EXL rear brake pads by myself. I was nervous about the E brake actuator and how to wind the actuator in order to push back the pistons. I did a lot of research and surfing on youtube and found an easy solution to all of this. You do not need a OBD scanner or take off the actuator and manually turn it with a screw driver or hex. The easiest solution to all of this is to follow these steps:
1. Disconnect the plug that is connected to the actuator. This will prevent any communication back to the main computer in the car.
2. The next thing you want to do is use a battery (9-12v) and 2 alligator clips (red and black). If you don't have one use the car battery and a jumper cable.
3. Clip the alligator clips to the two electrical leads inside the actuator that is connected to the caliper. It doesn't matter which one you pick.
4. Touch the other end of the alligator clips to the positive and negative terminals of the battery. You should hear the actuator spin. Make sure to watch closely to see if the piston is retracting or pushed out. If the piston is being pushed out, stop and reverse the leads you have touching the battery. By doing this the actuator will spin in the other direction. This will take at least 30 sec or so depending on how strong is your battery.
5. When you see the piston turn to the left, you can stop touching the battery with the alligator clips. The actuator is finished unwinding.
6. All you have to do now is push in the piston and connect the plug back to the actuator.
Step 4 alternative - If you are using a jumper cable attached to the battery, then touch the alligator clips to the red and black jumper cables.
Hope this helps out. This was the easiest way without taking apart anything, This video should help out a lot.
Take the cover off and just manually spin it using hex (I did that when I changed my pads few thousand KM ago, it’s the easiest way. Things can go very wrong when connecting a battery directly to terminals.
This thread was helpful. Wanted to add a few things to help anyone doing this for the first time.
1. Use a T-30 torx bit for the small bolts holding on the parking brake actuator. I removed this first so I didn’t have to try to hold the caliper while breaking loose the bolts.
2. A thin 17mm is helpful for holding the caliper slide pins when loosening the 13mm caliper bolts.
3. A T-47 torx bit is perfect for spinning the parking brake piston out (clockwise till it stops).
4. Caliper bracket bolts are 17mm. Recommend a half inch breaker bar.
5. An impact driver (and PB Blaster) is strongly recommended for removing the Phillips head disc retaining screw. Use anti seize when reinstalling and just hand tighten.
6. The piston (once the emergency brake actuator is removed) compressed straight back into the caliper. No need to spin it back. Just use a compression tool or c-clamp.
1 - 10 of 10 Posts
