Laphroaig said:
On the Valvoline WebSite, both ATF have the same PDF specs and here's what's written on their website about VV324: High-performance seal conditioners maintain and preserve the elasticity of seals to help prevent leaks
There seems to be no difference between VV324 and VV337.
I'll check on the bottle next time.
You missed the difference, because it's not published on the MSDS.
It's published on their adspace pages though. One has a stop leak additive, the other does not. They have identical physical characteristics to let us know that no matter which MaxLife Dex/Merc you choose, you'll get the same hydromechanical properties from either one. In short, same shift and friction qualities, etc.
VV324 and VV337 are identical in terms of flash point, pour point, viscosity, etc. However, the blend (which is proprietary, and not on the MSDS .pdf) will either have a seal conditioner (which maintains seal lubricity, most likely via that silicone-based compound I mentioned)
or a conditioner
and a stop leak (compound that will, even in very small concentrations, appreciably swell already-shrunken seals). Like you said, it'll say what it is on the bottle. One will be a stop leak formulation/blend, one won't be.
I found this out a couple years ago from a supplier in Oklahoma while trying to buy a 5gal keg of MaxLife (yes, they make these). Just thought the keg would be easier to use, because it certainly was less expensive per quart. They just won't sell it to us consumers, only to retailers.
You'll note that none of the makers (Castrol, Pennzoil, Ashland nee Valvoline) publish their blend formulas, but will only give physical and basic chemical qualities on the MSDS, and nothing more.
I never understood why ATF makers put stop leak in a bottle of ATF and advertise it as such. It's better to simply sell generic ATF with the ubiquitous seal conditioners, and sell stop leak in a separate bottle. I've cured a number of leaky tailpieces that way on the occasional TH400 or C4 transmission...the stuff works, or at least forestalls a seal changeout for a few more years.
By the way, the ATF-Z1 (which is produced in the U.S.) has seal conditioners as well. ATF-Z1 has a very high silicone base, for seal lubricity and to serve as a friction modifier for the clutch packs.
Regarding using Castrol, Mobil, or Valvoline, I agree with what Joel said (
MTPockets80):
'Gawd knows "genuine" Honda ATF-Z1 doesn't keep them from grenading. How bad can it be?'
. I mean, if my local Wally World stopped selling MaxLife, and started selling the other arguably high-quality products, I'd use those as well.
