Hey guys,
I need some help... I recently attempted to replace the factory speakers in my '04 Oddysey (with factory video system).
I installed the following:
Front door speakers:
(2) Focal RSE-130 [5 1/4"] speakers
NOTE: These are component speakers (woofer/tweeter separate). I installed the woofer only in each door.
Front tweeters:
....Couldn't get the grills off, so I left the factory tweeters in place. I have the Focal crossover & tweeters that are still in the box (the Focal RSE-130 Component speakers)
Rear speakers:
(2) JBL Club 5020 [5 1/4"] speakers
NOTE: These are 2-way speakers (woofer/tweeter)
Receiver:
JVC KW-R8925BTS
Now, here are my questions...
1) Is there a crossover between the front dash tweeters and the front door speakers? or is it just a Y split from the receiver (full-range sent to door speaker and dash tweeter)?
2) Is the front door speaker supposed to be JUST a woofer (part of a component system), or a two-way speaker w/ a tweeter? I saw someone post that they installed a two-way speaker in their doors...
3) Does anyone know what Impedence the factory speakers are/were? I stupidly threw mine away when I pulled them out of my car.
4) Regarding the Impedence...Are the speakers I bought going to work?? The Crutchfield guy told me the JBL's are 3 Ohm speakers & the Focals are 4 Ohm speakers. I still have the factory radio (uninstalled) & it has a 4 Ohm symbol on the top near the serial number...but it's unclear if it's referencing the audio amp or if that's regarding something else. Here's the info for the JVC I installed:
6) This is the big question...The one that ties everything together... When I installed all of the above (leaving the factory tweeters and using the Focal woofers in the doors), it sounded HORRIBLE. The Focals are WAY quieter than the factory speakers were...So the tweeters get loud a lot faster than the woofers, causing the balance to be wretched between the tweeters & woofers... Unlistenable....Which leads me to believe the factory tweeters & woofers were 2 Ohm speakers.
BUT why would they be 2 Ohm speakers if the Factory receiver had a 4 Ohm amplifier?? Were they just spec'd like that by someone at Honda who knew nothing about matching impedence between a speaker & amplifier??
7) SO, if I figure out how to get the tweeter grills off & install the correct matching Focal tweeters, how to I install the crossovers? Where do I look for where the wire splits from the receiver? I need a series of pictures or a video. I know it's supposed to be inside the "Under Dash Fuse/Relay Box", but I only know where that is on the passenger side...And I don't know how to get into it to change the wiring.
Anyways, I haven't had any sleep for weeks because this has been so frustrating to figure out. I've scoured the forums and I haven't found any answers to these questions. I've called Honda several times and they haven't been able to answer any of them...Praying someone else on here knows something about audio that can help.
MANY THANKS. PLEASE HELP ME
Jake
Front tweeters:
Rear speakers:
Receiver:
JVC KW-R8925BTS
- Full Bandwidth Power: 22 watts RMS x 4 channels (at 4 ohms, 20-20kHz, 1% THD)
- Maximum Output Power: 50 watts x 4 channels (200 total watts)
Jake
