Status
Not open for further replies.
2008 Honda Odyssey Technical Service Bulletins
124K views 64 replies 32 participants last post by  EE4Life
#1 · (Edited by Moderator)
TSB 07-065 - Steering Column Pops or Clunks While Turning or Accelerating
Applies To: 2007–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A07-065.PDF
LinkDeny
TSB 08-006: Power Sliding Door Buzzes While Opening and Closing
Applies To: 2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B011536
From VIN 5FNRL38..8B400001 thru 5FNRL38..8B401792
http://www.urvi.net/forumfiles/SB/A08-006.PDF
TSB 08-012: Service Manual Update: Factory-Installed HFL (HandsFreeLink) General Troubleshooting Information
Applies To: 2008 Accord With Navigation – ALL
2008 Odyssey With Navigation – ALL
http://www.urvi.net/forumfiles/SB/A08-012.PDF
TSB 08-017: Engine Knocks or Ticks at Idle
(Supersedes 08-017, dated April 2, 2008, to update the information marked by the black bar)
Applies To: 2008 Odyssey EX-L/Touring: From VIN 5FNRL38..8B000001 thru 5FNRL38..8B019499
From VIN 5FNRL38..8B400001 thru 5FNRL38..8B403623
http://www.urvi.net/forumfiles/SB/A08-017.PDF
TSB 08-026: Product Update: Audio Unit Display Is Not Readable or Tune and Volume Knobs Do Not Work
Applies To: 2008 Odyssey (except LX) – From VIN 5FNRL38..8B061204 thru 5FNRL38..8B065332
2008 Odyssey (except LX) – From VIN 5FNRL38..8B417185 thru 5FNRL38..8B418985
http://www.urvi.net/forumfiles/SB/A08-026.PDF
TSB 08-029: Outside Temperature Display Is Higher Than Actual After Hot Restart
Applies To: 2008 Odyssey EX, EX-L, Touring
– From VIN 5FNRL38..8B000001 thru 5FNRL38..8B060123
– From VIN 5FNRL38..8B400001 thru 5FNRL38..8B416795
http://www.urvi.net/forumfiles/SB/A08-029.PDF
TSB 08-051: DVD Read Error, or No Route Displayed, and Navigation DVD Is Scratched
Applies To: 2008 Odyssey models with navigation from VIN
5FNRL3...8B000001 thru 5FNRL3...8B004881
http://www.urvi.net/forumfiles/SB/A08-051.PDF
TSB 08-055: Sliding Door Does Not Open All The Way
Applies To: 2005–08 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A08-055.PDF
TSB 07-005: Power Steering Pump Whines, Buzzes, or Hums
Applies To: 2005–07 Odyssey – ALL 2008 Odyssey – From VIN 5FNRL38..8B000001 thru 5FNRL38..8B075356
2008 Odyssey – From VIN 5FNRL38..8B400001 thru 5FNRL38..8B419525
http://www.urvi.net/forumfiles/SB/A07-005.PDF
TSB 07-044: 2008 Honda Paint Codes
Applies To: 2008 Honda – ALL
http://www.urvi.net/forumfiles/SB/A07-044.PDF
TSB 07-069: 2008 Odyssey: PDI and New Model Information
Applies To: 2008 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A07-069.PDF
TSB 06-068: Vehicle Pulling or Drifting
Applies To: ALL
http://www.urvi.net/forumfiles/SB/A06-068.PDF
TSB 06-072: TPMS Sensor Tool Usage
Applies To: 2007–08 Odyssey – ALL except Touring
http://www.urvi.net/forumfiles/SB/A06-072.PDF
TSB 05-032: Navigation System DVD Information and Inspection
Applies To: 2000–08 Odyssey
http://www.urvi.net/forumfiles/SB/A05-032.PDF
TSB 08-071 Engine Pings During Moderate to Heavy Acceleration
Applies To: 2007 Odyssey – ALL
2008 OdysseyLX, EX:
Production Line 1 –
FromVIN 5FNRL38x.8B000001
thru 5FNRL38x.8B037706
Production Line 2 –
FromVIN 5FNRL38x.8B400001
thru 5FNRL38x.8B410388
NOTE: x equals 2 or 4
EX-L, Touring:
Production Line 1 –
thru 5FNRL38x.8B037448
Production Line 2 –
thru 5FNRL38x.8B409144
NOTE: x equals 6, 7, 8, or 9
http://www.urvi.net/forumfiles/SB/A08-071.PDF
TSB 08-080 Wind Noise or Rattle From Front Doors
Applies To: 2008 Odyssey – From VIN 5FNRL38..8B000001 thru VIN 5FNRL38..8B093699
2008 Odyssey – From VIN 5FNRL38..8B400001 thru VIN 5FNRL38..8B419525
http://www.urvi.net/forumfiles/SB/A08-080.PDF
TSB #08-084 Time on Display Changes Randomly
Applies To: 2005–09 Odyssey with Navigation – ALL
http://www.urvi.net/forumfiles/SB/A08-084.PDF
TSB #08-088 Service Manual Update: Poor AM or FM Reception
Applies To: ALL 2004–09 Models
http://www.urvi.net/forumfiles/SB/A08-088.PDF
TSB 07-045 Brake Pedal Is Low and Feels Soft
Vehicles Affected: 2007–08 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A07-045.PDF
TSB 09-004 Parking Brake Indicator Stays on When the Parking Brake is Released
Applies To: 2008–09 Odyssey – ALL except Navigation
http://www.urvi.net/forumfiles/SB/A09-004.PDF
TSB #09-017
Gap Between the Front Passenger’s Airbag Lid and the Dashboard
http://www.urvi.net/forumfiles/SB/A09-017.PDF
TSB #08-078 Electrical Problems and B-CAN DTCs After Exposure to Water/Water Leaks
Applies To: 2005-2009 Odysseys
http://www.urvi.net/forumfiles/SB/A08-078.PDF
Not a TSB yet but a Honda Service News article for now: Camshaft Leaks Engine Oil at Pulley Mounting Bolt http://www.urvi.net/forumfiles/SN/A09050j.pdf
TSB # 09-047 MIL Comes On With DTC P0962, P0963, P0966, P0967, P0970, or P0971
http://www.urvi.net/forumfiles/SB/A09-047.PDF
TSB # 09-046 Sliding Door Center Seal Is Torn or Worn
http://www.urvi.net/forumfiles/SB/A09-046.PDF
Power Sliding Door Stops at Half-Latch Position, Won’t Close
Currently Applies To: ’05–09 Odyssey
http://www.urvi.net/forumfiles/SN/A09060t.pdf
Rear Wheels Howl or Moan When Braking
http://www.urvi.net/forumfiles/SN/A09060o.pdf
TSB 09-053 Product Update: Lock-Up Clutch Judders Between 20–45 MPH
Applies To:
2009 Odyssey LX, EX:
Production Line 1 –
FromVIN 5FNRL3...9B000351
thru 5FNRL3...9B056551
Production Line 2 –
FromVIN 5FNRL3...9B400201
thru 5FNRL3...9B410343
EX-L, Touring:
Production Line 1 –
FromVIN 5FNRL3...9B000201
thru 5FNRL3...9B050869
Production Line 2 –
FromVIN 5FNRL3...9B400321
thru 5FNRL3...9B405632
http://www.urvi.net/forumfiles/SB/A09-053.PDF
TSB 09-054 Power Doors Continually Lock While Driving
Applies To: 2007 Odyssey – ALL Touring models
http://www.urvi.net/forumfiles/SB/A09-054.PDF
TSB #09-080 - Water in the Inner Taillights in the Tailgate
http://www.urvi.net/forumfiles/SB/A09-080.PDF
TSB 09-085 Front Door Glass Opens/Closes Slowly or Sticks
Applies To: 2008–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-085.PDF
TSB # 09-051 Windshield Side Trim Retainer Is Loose or Broken
Applies To: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A09-051.PDF
TSB # 10-011 Service Manual Update: Power Window Goes Up and Reverses On Its Own,
Is Slow to Open and Close, or Squeals, Creaks, Clunks, or Clicks
VEHICLES AFFECTED: 2005–10 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A10-011.PDF
TSB # 10-017 Safety Recall: Air In VSA Modulator-Control Unit Causes Low/Soft Brake Pedal
Applies To 2007–08 Odyssey – ALL
http://www.urvi.net/forumfiles/SB/A10-017.PDF
TSB 08-045 Chirp From the Timing Belt Area
Applies To: 2005–2007 Accord V6 – ALL
2005–2008 Odyssey – ALL
2005–2007 Pilot – ALL
2005 –2007 Ridgeline – ALL
http://www.urvi.net/forumfiles/SB/A08-045.PDF
TSB 10-024: No XM Sound, But XM Station Information Is Displayed
http://www.urvi.net/forumfiles/SB/A10-024.PDF
TSB 10-042 Clunking, Popping, or Clicking While Turning
Applies To: 2007–09 Odyssey – ALL
2010 Odyssey – From VIN 5FNRL3...AB000001 thru 5FNRL3...AB028891
http://www.urvi.net/forumfiles/SB/A10-042.PDF
TSB 10-060 - 2008–10 Odyssey: MIL Comes On With DTC P0300 Thru P0304
Applies To: 2008–10 Odyssey EX-L, Touring – ALL
http://www.urvi.net/forumfiles/SB/A10-060.PDF
TSB 10-074 - Rear Bumper Sticks Out
http://www.urvi.net/forumfiles/SB/A10-074.PDF
TSB 10-076 - Steering Wheel Is Hard to Turn Quickly at Low Speeds
http://www.urvi.net/forumfiles/SB/A10-076.PDF
TSB 11-003 - 2008–10 Odyssey: MIL Comes On with DTC P0128
http://www.urvi.net/forumfiles/SB/A11-003.PDF
SYMPTOM
The MIL comes on with DTC P0128 (cooling system
malfunction).
PROBABLE CAUSE
The PGM-FI software misinterprets sensor inputs as a
cooling system malfunction, causing DTC P0128 to be
set.
CORRECTIVE ACTION
Update the PGM-FI software with the HDS.
TSB 11-033 - Engine Oil Consumption; MIL May Be On With DTC P3400 and/or P3497
http://www.urvi.net/forumfiles/SB/A11-033.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A11-033.PDF
TSB 12-011 - Safety Recall: Power Tailgate May Not Stay Open
Applies To: 2008 Odyssey EX-L Touring – Check the iN VIN status for eligibility
2009 Odyssey EX-L, EX-L with RES, Touring – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A12-011.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A12-011.PDF
TSB 13-031 - MIL Comes On With DTC P3400 and/or P3497
Applies To: 2008–11 Odyssey EX-L and Touring - ALL
2012 Odyssey - From VIN 5FNRL5...CB000001 thru 5FNLR5...CB138229
http://www.urvi.net/forumfiles/SB/A13-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-031.PDF
TSB 13-080 - Warranty Extension: MIL Comes On With DTCs P0301 Through P0304
Applies To: 2008-10 Odyssey – EX-L, Touring – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-080.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A13-080/enu/A13-080.PDF
TSB 13-098 - Safety Recall: 2007–08 Odyssey VSA System Unexpectedly Activates
Applies To: 2007–08 Odyssey – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A13-098.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/A13-098.PDF
TSB 14-015 - Safety Recall: Odyssey Fuel Smell or Leak
Applies To: 2005–10 Odyssey – ALL – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-015.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-015/enu/A14-015.PDF
TSB 14-032 - Safety Recall: Odyssey Fuel Pump
Applies To: 2005-10 Odyssey - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/A14-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-032/enu/A14-032.PDF
TSB 14-073 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 Odyssey - ALL
http://www.urvi.net/forumfiles/SB/A14-073.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A14-073/enu/A14-073.PDF
TSB 19-111 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2005-17 Odyssey
http://www.urvi.net/forumfiles/SB/A19-111.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A19-111/enu/A19-111.PDF
TSB 20-023 - Front Rocker Arm Oil Control Valve Leaks
Applies To: 2008-10 Odyssey - EX-L and higher - ALL
2011-17 Odyssey - ALL - ALL
http://www.urvi.net/forumfiles/SB/A20-023.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/AH/A20-023/enu/A20-023.PDF
#5 ·
NDNV,
You seem to obtain this information quite a bit. Its a good thing. Do you think it would be better to catalog it under one thread containing several posts (each post for a model year or something of the sort)?
We'd be hard pressed to have the mods sticky all the good stuff you post but if we break down your information into a few threads, the mods might bite and make it sticky. Just a thought I had and was wondering what your opinion would be.
Thanks for continuing to post the TSB links and Honda News.
Save
#7 ·
Yeah, I'm open to suggestions concerning the format etc. I intend to create a new thread for each model year. One thread for all might get confusing over time. As new TSBs are created, I can edit my first post at the top of the thread and add to the list. The main benefit of doing it this way is that I can search here on a topic and pick my user name to narrow down the search to this thread and pick out the applicable TSB.
When I get the time, I'll be working my way back in model years. (i.e. next up 2007, 2006, 2005, etc.)
#8 ·
Much appreciated NDNV. My temp display is wonky, nice heads up.
Any Shop Talks or TSB's for squeaky driver seat ALL THE TIME SO IT DRIVES YOU CRAZY???
tia
#9 ·
#10 ·
Thanks for the last one, my driver door rattles like a demon. I taped that trim piece on the outside and it stopped. I think I will just take it off and do it myself.
The dealer needs my van for a whole day just to do a 0.3 repair? :cool:
#11 ·
My 08 right front door has the rattle, too. Drove me NUTS on my last drive to Arizona.
I hate taking my cars to the dealership; always seems like they repair something and screw something else up... dirty floor mats, sprayed chemicals on the wheels, Lexus dealer curbed a wheel, etc.
Thanks for the post; I'll try the suggested repair!
Now if I can just address the squeaking right sliding door...
Save
#13 ·
Defective Power Steering Reservoir
Thanks for this list! My van started the whining noise today while it was 35 degrees outside. Now I know what is going on (afraid it was the transmission). :eek:
Save
#14 ·
so glad i found this thread today. i have the door rattle issue and it just so happens that my Ody is at the stealership right now having the clear mask, tint, and RES installed, so they are going to fix the door rattles as well. perfect!
#17 ·
Have there been any TSBs about braking or brake pedal feel? My 08 brake pedal travels way further than my 05 ever did. Very disconcerting.
Dealer said they have received many comments about it but it is working as planned. Any ideas?
Save
#19 ·
iceracer said:
re brake pedal travel...
Have your dealer bleed the brakes. It took me 3 attempts to convince them but it made a noticeable difference on an 07.
Thanks, I will try that. They balked when I asked them to do that, will try again.
Save
#21 ·
Found this link at the Edmunds Odyssey site. It is a 2007 TSB that has been expanded to include all 2008 Odyssey's. It appears that air is entering the brake system through the ABS/TCS or VSA modulator-control unit.
(Supersedes 07-045, dated October 25, 2007, to revise the information marked by the black bars)
REVISION SUMMARY
• Odyssey models have been added to the VEHICLES
AFFECTED, PARTS INFORMATION, and
WARRANTY CLAIM INFORMATION sections.
• Under WARRANTY CLAIM INFORMATION, the
operation number and flat rate time for manually
bleeding the brakes were added.
SYMPTOM
When you apply the brakes, the brake pedal travels
lower and feels softer than normal.
PROBABLE CAUSE
The ABS/TCS or VSA modulator-control unit has
leaked air into the brake system.
VEHICLES AFFECTED
2003–06 Accord V6 – ALL
2007 Accord 2-door V6 A/T:
From VIN 1HGCM822.7A000001 thru
1HGCM822.7A004921
2007 Accord 2-door V6 M/T:
From VIN 1HGCM817.7A000001 thru
1HGCM817.7A007683
2007 Accord 4-door V6 A/T:
From VIN 1HGCM665.7A000001 thru
1HGCM665.7A102801
2007 Accord 4-door V6 M/T:
From VIN 1HGCM655.7A000001 thru
1HGCM655.7A076301
2005–06 Accord Hybrid – ALL
CORRECTIVE ACTION
Replace the ABS/TCS or VSA modulator-control unit
(modulator assembly).
#22 ·
Fantastic! Thanks so much I will get my dealer on it. I knew I wasn't crazy!!
Save
#23 ·
Just came back from the dealer and the brakes work amazingly well now. In fact the pedal is touchy since I was used to pushing the thing about 6-8 inches it seemed.
I am very happy to have this remedied.
If you have an 07 or 08, go get this done! You will be very happy!!
:D
Save
#24 ·
bump.
Save
#26 ·
famman said:
No need to bump. I did unsticky the individual threads but did post a new consilidated sticky thread up top after conferring with NDNV to reduce the number of stickies uptop.
Save
Status
You have insufficient privileges to reply here.
