2010 power steering noise
4.1K views 3 replies 3 participants last post by  chancwj
i replaced the ps pump in my 2010 oddy and when i try to get the air out by turning the wheel foam fluid comes out of the reseviour!! i spent $40 on fluid already. the problem started a month ago after long drives. the ps pump whines badly. please help! how do i get the air out of the system? also tried flushing by taking the return line off.
#3 ·
...the ps pump whines badly. please help! how do i get the air out of the system? also tried flushing by taking the return line off.
Air is still getting into the PS system.
Some Honda/Acura V6 PS units require replacement of the PS inlet (low pressure side) hose O-ring at the PS pump. The O-ring is usually less than $1 at the dealer and takes about 5 minutes to replace by removing one bolt. A YouTube video showing O-ring replacement(albeit for an Accord V6, but same idea and physical parts placement) is at: 03 07 Honda Accord power steering fix - YouTube!.
Air is removed from the PS by turning the steering wheel lock-to-lock a few times slowly, or just driving a route with some turns for a bit.
G/L, and welcome to OdyClub.
