2013 Odyssey Touring Elite RCA inputs? Not the rear inputs...
5.3K views 1 reply 1 participant last post by  theevolwun
Hello, I have an old subwoofer I would like to install in my TE. The method I've used in the past was by connecting RCA jacks to an audio out jack on the back of an aftermarket head unit.
Does anyone know if the OEM stereo or NAV unit has RCA jacks available for this purpose? Do the rear RCA's only work for the RES?
Thanks.
TE1
The rear RCA inputs only work for RES. No RCA inputs on the OEM stereo or NAV.
To connect my sub I used an RCA lineout converter and spliced into the LH & RH rear speakers under the sliding door sill plates. Spliced into the Orange and Gray wires (left door), then Pink and Purple wires (right door). Also had to disable the Active Noise Control module (ANC) located behind the glove box.
Thread closed.
