I have a 2018 model bought in late 2017. Recently the front brakes started squealing. We only have 20k miles on the van but after looking at the brakes the inner pads may be wearing faster.
Maybe wearing?
Did you look through the wheels spokes to assess the state of outboard pads?
Removed the wheels to inspect the inboard pads?
Just because brakes are squealing, doesn't necessarily mean that the pads are worn.
3 out of 4 times I hear squealing come from the brakes of my cars it's due to a stone that got stuck between the caliper and the rotor, or rotor and the dust shield.
Only one, luckily quick and easy, way to confirm: take the wheel off, and inspect!
Checked online at AutoZone and Oreilly and neither show front brake pads as being available? Are their no aftermarket pads available yet?
You can buy the pads from the dealer, and DIY install them.
The last time I did that, the pads were exceedingly reasonably priced, and are always in stock.
Also, anyone else have to change theirs so soon?
20K miles is kinda early.
But if you drive the car in spurts, let it sit outside, and allow dust to form on the rotors, they will start acting like cheese graters, and will significantly shorten the lifespan of the tires.
If the rotors aren't perfectly smooth and show signs of rust pitting - replace them as well!
If the inner pad is wearing faster than the outer, it means the piston isn’t compressing with vacuum.
Clarification - pads are pushed towards the rotor with the force of hydraulic fluid pushing against the piston (which pushes onto the pad). When the pressure is relieve, the pad is knocked back a bit by the surface of the rotor, but there is no vacuum involved in brake system operation.
On floating design rotors with one inboard caliper (common in most non-race car applications), it's entirely normal to see higher rate of wear on the inboard pad that is directly depressed by the brake piston.
The outer pad gets involved when the caliper transfers the squeezing pressure to the side opposite to where the piston is mounted. There is always some distortion in caliper movement, and the outboard pad typically applies a little less pressure than the inboard pad, and that gets reflected in slight difference in pads' wear rate.
Changing out pads is really easy, and will hold you over until they can warranty your brake issue.
I totally agree that swapping brake pads (and rotors) is by far the easiest and the highest money saving regular maintenance job that a person can perform on their car.
However, I'm pessimistic that there can be any warranty claim on brake pads wear. Pads are a consumable part of the car, just like tires are, and I haven't heard of any automotive OEM that would warranty either one.
Good luck,
a
