2019 Front power Socket no power (Relay Location)
8.7K views 12 replies 6 participants last post by  DJVAN
Hi.
I don't have 12V at my front power socket and also the 3rd row seat power socket.
Would anyone have a wiring Diagram available that could guide me along the way?
There has to be a relay in the line somewhere but I do not have a leged of the relays. (I did find a helpful thread on here for the cargo area outlet though)
Fuse 22 is good 12v is there
Thanks
#2 · (Edited)
@MikeySQ
Here is an update Fuse Location Index and Relay Locations. It may take a few minutes to understand the Fuse one, but it is all there.
Reactions: KickStart
#3 ·
update, i just found out that it wasn't a relay, although i think there is one somewhere as with the read cargo 12V socket!
it ended up being the Socket itself, with more searching and I found @pete_dallas2011 post on the socket and it gave me the thought to check it... quite the safety socket with these, metal plates in there not a hard connection!
thread that pointed me in the direction!
#12 ·
@Honda2021
Here is a chart to check the path for voltage to the compressor.
Thank you the pdf’s, and your knowledge, that you share with us. I don’t need this stuff now, but might in the future. I’ve saved the files for that time.
