61 - 80 of 80 Posts
Discussion starter · #61 ·
Oh no, you took a guess and fired the parts cannon at it? You were doing so well troubleshooting, too. Always test, don't guess! You really don't even need to jumper pins 2 & 3. You need only ground pin 3 while pins 1 & 4 are connected. If you don't have backprobes to check when plugged in then you can unplug and jumper pins 1 & 4 and then jumper pins 2 & 3. If high speed still doesn't work then just manually ground pin 3. A bad ground on G401 would also cause the high speed to not kick in at 221psi.
Newbie
Just joined and have been reading your thread. Not sure if I'm in the right place, but it seems like you sure know what your doing. I have an 06, 193K miles, I'm the original owner, and never wrecked. I have replaced three a/c relay's. A/c will run for no longer than 10 or 20 miles. But it does run every time after sufficient cooling, usually the following day. Any ideas, I'm in the process of checking all fuses.
TIA
Discussion starter · #63 ·
TIA
You need to first determine if it's a cooling fan issue or a compressor issue.
Mystery solved: TSB 07-051 fixed my issue.
If you have a Foxwell NT510 scanner you can easily solve this symptom of both fans run low speed, but on high speed when the condenser heats up and the pressure goes above 220 at idle and stop/go traffic.
Make sure you remove VCMuzzler if you are troubleshooting. The fans should come on high speed when the coolant temp is high enough w/ or w/o AC on. Use the scanner to turn on Radiator fan on (it runs high speed) when the key in on II. That makes sure you have no other issues with the circuit. You also need to know that the system is charged correctly and that it actually reaches 220+PSI. Under ECU Information the version of your PCM will be listed there. It says serial number on the Foxwell, but that is actually the part#. Mine was 37805-RGM-A83 which is Program ID GMA830. You need to have GMA840 or higher. That part number is 37805-RGM-A84.
I wanted to share with any 07' models that fit the applicable VIN range in the TSB: http://www.urvi.net/forumfiles/SB/A07-051.PDF
Thanks for all the help on this forum esp John Clark. I used the TSB to negotiate a lower rate at the dealership from 1hr to .8. They said even though the TSB quoted .2+.3hrs, they use that only for warranty claims. Oh well, it cost $108 because I had no Goodwill here in Delaware with the dealership I found on vacation. Either way I'm thrilled to be done.
TIA
Even though I'm decent as a shade-tree mechanic, I found an A/C mechanic in my area that could evac my system and refill refrigerant by weight. It cost $80 although his regular price was $130. You can tell alot from the gauges, but take care when they remove the gauges to check the service ports for leaks because mine was sticky. The mechanic was the one who told me my fans wouldn't go into high speed.
Bringing and old thread back to life as I am running into the same issue. Mine is an 07 with 280k miles, the AC runs fine when the car is being driven but blows warm air when the car is idling or is in stop and go traffic. I do have the VCM muzzler that has been on for a few years now. Neither the radiator or the condenser fan come on when the car is parked and the AC is turned on, I have installed a new relay for the AC fan but that didnt fix the issue, both the condenser and the radiator fan 30A fuses are good.
Any ideas as to what might be the cause of this issue?
I am thinking I may need to get the TSB done in order to see if my issue is TSB related.
Anything else that I can do in order to fix the issue before driving the car to the dealer?
Discussion starter · #67 ·
If the fans are not running the condenser will get extremely hot and can overpressurize. You need to get this figured out before you cause more damage.
The TSB mentioned above assumes the fans run on low speed when the AC is on but don't switch to high speed. It doesn't sound like your issue is the TSB issue. Some electrical troubleshooting will be necessary. Do you have any tools like a volt meter or test light?
Thanks foe the prompt response. The compressor was changed a few years ago and I remember having the same issue back then as well, google didnt help and a bit of searching here on the board didnt really help either as I remember changing the relay for the fan back then and it didnt fix the issue.
I do have a volt meter and the complete factory service manual.
At first I thought it had to do something with the VCM muzzler where the ECU is not triggering both fans thinking that the engine is not warm enough but that didnt make sense as turning on the AC should automatically turn both the fans on, so here we are today with neither one of the fans kicking in when I turn on the AC.
Any ideas where should I start? Again, I really appreciate and help.
Discussion starter · #69 ·
The fan circuit is a bit complicated. The fans run at two different speeds. They have a low speed that should be commanded on when the AC is commanded on so if the compressor is running the fans should both be running at low speed. When the pressure in the high side of the AC hits 221psi the pressure switch B should close to tell the computer to kick the fans on high speed. In low speed the fans run in series, off of the #9 (30A) fuse and condenser fan relay. In high speed the fans run directly off of their respective fuse and relay.
So, the first test I would do is with the engine running, AC commanded on, and compressor verified running. Pull the AC condenser fan relay and check for two power feeds. You can do this with your volt meter. Connect the black lead to a good ground and carefully touch the red lead to each of the terminals in the fuse box (relay unplugged,) being careful not to push the probe down in and damage the terminals. You should have two power feeds, one for the load side (fan motor) and one for the control side of the relay (tip: the two wide terminals are the load side and the two narrow terminals are the control side of the relay.) If you have two good power feeds, then connect your red lead to the positive battery terminal and use the black lead to probe the other two terminals. Both should have good grounds. One will be a ground through the fan motors and the other will be a ground from the PCM, commanding the fans to low speed. We need to determine what is missing...a ground or a power. If you can tell me what you find on that relay we should be able to determine what's going on.
Interesting postings..
I updated my Foxwell NT520 with new Honda package. Tried to run the radiator fan from the foxwell scanner. It wont turn on. With the AC on in the garage, both fans turn on at high speed. Once the AC is off, both fans will stop. So the fuse, relay are good for both the fans. Also the connectors at the fan.
Wonder why the scanner cant turn it on. It can command all others in the list like fuel pump, ac clutch etc. All of them works except the radiator fan. Its status shows "off" and "on" option does not do anything.
Van never overheats and it is 100+ here in North Dallas. I think the high speed fan is making it work.
Discussion starter · #72 ·
I just tried my NT510 and it toggled the fans just fine. I did notice that it didn't do anything if I had the HVAC system on and the fans already running on low.
I remember trying it and it was working some time back (when i bought the scanner). Don't know if it is new software pack or the PCM is not commanding it for some reason. But with AC on, it is commanding it to run at high speed. AC also works fine in at all cases (idle, stop at light etc)
I will try with HVAC off (make sure it is off).
BTW, you tried with engine on or off? I tried it with engine off. F2 is for on and F3 for off (or vice versa on it)
Will update tomorrow. Only in the morning, i can go to garage. So hot.
Is there an option to control the AC fan also? Or only for the engine fan?
Discussion starter · #74 ·
I tried it with engine off. When I commanded it on, both radiator fans went to high speed. It doesn't do anything with the interior blower fans.
Tried it just now. It is working fine.
1) When AC is on,it runs in slow speed
2) With AC off, i commanded it from Foxwell. Both fans run in high speed.
All the tests were done with engine off. I think i tried it with AC on last time so that it is little cooler with the fan.
Thanks John..
Right on!
This is really a very good thread. Thank you very much. I followed it and check everything on the car. I have problem my fans do not go to high speed after switching ON the AC. They do run at low speed. I followed the diagram you attached to bypass the pressure switch and fans still do not run to high speed. I looped and pin 2 and 3, pin 1 and pin 4 as you suggested but still not running. I checked for continuity on pin 2 found NO continuty. I put ground on pin 3 and still fans do not go to high. It looks that there is a problem with wiring.
any idea how I trace the problem. I need the circuit diagram from the pressure senser to control .
I’m working through a similar issue, but I’m having some trouble locating the pressure switch. Can someone help me out with where it is located?
So, to make a long story short, if you have a 2007-2009 Factory Service Manual I suggest adding the box Honda left out of the Symptom Troubleshooting Index on page 21-14:
Symptom
Both fans run on low, the condenser fan runs on high, but the radiator fan does not run at high speed.
Diagnostic Procedure
NA
Also Check For:
Blown fuse No. 11, 30A in underhood fusebox
Radiator Fan Relay stuck open
They have a Symptom Troubleshooting Index line for just the opposite... i.e.Both fans run on low, the radiator fan runs on high, condenser fan does not run on high and they have you look at fuse #9 and #30.
Just joined, the Odyclub helped me a lot with avoiding a bad decision of trusting the dealer on ring replacement due to VCM issues...and this thread just solved another. I've been having issues with my AC blowing hot at idle, quicker on hot days that cooler ones. I checked Fuse No.11 under the hood and low and behold it is blown. Going to get a replacement tomorrow and enjoy not having my AC turn into heat at stop lights and in drive thrus.
61 - 80 of 80 Posts
