UPDATE:
Hello fellow OdyClubbers, so I did use Aisin DW1 atf for a few weeks, and decided to get rid of it, and switch back to Valvoline Maxlife atf.
The reason behind it - my transmission is worn out, not sure what exactly, but most likely clutch packs. Not long ago I finally fixed a slippage, the fix was - the replacement of all shift solenoids. Slippage was gone, but 4th gear still had a lag and wasn't locking up properly. Aisin DW1 atf made that lag worse. Switching back to Valvoline Maxlife made things better, the 4th gear is locking much quicker. Not sure why exactly Maxlife is better for my particular transmission, but my guess is - different viscosity. Aisin DW1 viscosity is very close to Honda DW1, while Maxlife viscosity is higher. I had similar results with Redline D4, and Redline D4 also has a higher viscosity than Honda DW1. Redline is just too expensive nowadays, so I'll be using Valvoline Maxlife from now on.
I am not saying that everyone should use Maxlife atf, but for worn-out transmissions, it is probably a better choice.
Hello everyone! Its about time to change ATF again. I always do complete drain and fill, so it'll be around 9 quarts or so.
Given today's prices, I start looking around for something other than Redline D4. Honda DW1 also not cheap anymore, even Maxlife cost $26 per gallon now.
So, I found this AISIN ATF at rockauto. Did anyone use it? Forum search brings nothing but AISIN TB kits, sorry )
