Klumley replied to me in several PM's and gave me the go-ahead to post them here for other reader's benefit.
quote:
Originally posted by LuvMy06EXL
Do you know what brand/model #/part number of solenoid was used in your set up? ...
Also, are you able to tell which wiper motor wire was tapped into? ...
Thanks for any time you spend answering these questions.
I'm sorry not to be of much help to you - we had our wiring installation done at a local RV shop 2-years ago now, and I can't say as I've been following the posts on this forum since.
Unfortunately, I couldn't tell you the make or type of solenoid used, and where the power supply was spliced into the wiper circuit is nicely taped up. Without a manual, I couldn't suggest which wire to tap into, but I doubt it would be the blue or the yellow - you'd need to tap into the appropriate [hot] wire leading to the switch.
If you're absolutely stuck, PM me again and I'll try to get some close-up pics of the solenoid & wiring installation.
Cheers,
Ken
quote:
LuvMy06EXL wrote on 04-08-2007 07:34 AM:
... I knew it was a long shot in you being able to recall or look up any additional details ...
By the way, I take it your Ody's trailer wiring has worked as advertised ...
Having looked at it in daylight, there is nothing discernable on the solenoid that would lead me to a part # or manufacturer. However, the power supply is tapped into the GREEN wire for the wipers. As I mentioned in my posts, the Honda tech was no help at all as they won't undertake any liability for aftermarket meddling.
Yes, the installation has worked 'as advertised' coming into the 3rd season, though I'm noticing some corrosion on the exposed bits at the 7-pin hitch receptacle. On reading through the subsequent posts on this subject, I'm impressed with the effort & detail some of the DIY'ers are going to for a 'clean' installation.
Cheers,
Ken
LuvMy06EXL wrote on 04-08-2007 09:09 PM:
Thank you very much for checking your wiring and noting the green wired had been used. It caused me to re-review the wiring diagram and I see now why the green wire was selected for the relay. It is, in fact, in the main ignition circuit. I simply overlooked the little, black dot that indicated it was part of that circuit.
Regarding the solenoid, I'm going to call numerous trailer wire kit installers to find out which solenoid they use.
