I have a 2014 Odyssey LX with about 64,500 miles on it. I purchased the muzzler on 9, 2019. I had the brown resistor installed about a month after I got the muzzler because ECO light would turn. I liked that it drove smooth. On April 30th, the Check Engine Light came on while driving. On May 1st I moved the Odyssey a few feet forward and turned it off. I foolishly took out the muzzler, thinking it would turn the CEL light off. I then went to Autozone and the codes that came up were P0128, P0118, and U0029. Does the Muzzler have something to do with that? If so, what can I do? If not, what else could it be? Should I take it to dealer/ mechanic? Should I keep driving it? How can I tell offhand if engine is overheating? Without the muzzler, and no scanner available, could the CEL light eventually turn off or do I need the scanner?
I drove about 20 miles (with muzzler) and about 30 miles (without muzzler) after the CEL light came on and I did not notice any strain or struggle at all. The temperature gauge acted normal as far as I could tell and was right in the middle without the muzzler. My biggest fear is the engine overheating and being damaged but I don’t know what symptoms/ signs that would indicate that. Autozone recommends replacing Thermostat and/ or the ECT sensor. I messaged Verbatim already. I would like to know if any of you experienced this as well and how it turned out.
