Rmorton
Discussion starter · #1 ·
I was having issues with warm air blowing on the driver side of my 2010 Odyssey. I checked the blend door actuator and found it was working properly. I saw a reset to see if the climate control panel had any errors. I did this by holding down the Off button while tapping the Rear defroster button 5 times. It flashed three times and turned off which I understand that to mean everything is fine. The problem now is the unit won't come back on and the rear air is also off now. Any and all help is appreciated
I would suggest removing the battery cables, then touch the cables together for a second or turn on your headlights with the cables removed. Then reconnect the cables and see if things are working again. This will reset everything so have your radio and DVD codes. This drains any residual power much like unplugging your home PC, unplugging the power cable, and then holding the power button On for a few seconds. This method has solved PC USB conflicts for me in the past.
Sent from my Moto Z (2) using Tapatalk
