My parents had a silly debate on whether or not the clock had a backlight. I took it upon myself to do some research and as I suspected, there was indeed a backlight. I came across this thread and decided to fix the lamp. The instructions were very detailed and overall, the process was fairly simple. However, there was a lack of pictures and I noticed there was a demand for them. Hopefully, this tutorial will provide some help to the people who were afraid to do it themselves. Keep in mind, this was my first time removing a dashboard.
I’ll go step-by-step through the pictures, so you don’t have to juggle back and forth between this and the other thread.
TOOLS REQUIRED:
- 10mm or 1/4" socket wrench to disconnect battery
- phillips screw driver
- working gloves
- tiny flathead screwdriver to remove hazard button connector
- wrapped flathead screwdriver for prying. (not needed if you have small fingers)
1. Here’s the part you need to buy, Radio Shack part #272-1092. Despite Radio Shack’s rip-off prices, this was only $1.49 for two micro lamps.
2. Disconnect the battery. Personally, I don’t believe this step is necessary, but you can do it to be on the safe side.
3. Put on the emergency brake. With the engine off, shift down it into the lowest gear to give yourself some clearance.
TOOLS REQUIRED:
- working gloves
