My wife and I got our first Honda Odyssey in Feb. 2020, a 2019 EX-L with navi which had about 50k miles already. We're having an intermittent issue with the accelerator and the dealer doesn't seem to even believe us, much less have any idea what might be causing this. I know we're not crazy because there is a similar thread here: hesitation on acceleration Since that thread was about a different generation, I thought I would start a new thread.
Basically, when starting from a stop - either dead stop or coasting stop, but after applying the brake, when you start gently pressing the accelerator, nothing happens for an inordinate amount of time. Likely only a second, but feels much longer when you're trying to make a left hand turn in front of oncoming traffic. The van may be barely rolling, because the brake isn't engaged, but you're only coasting with no response from the gas pedal. Then, after the short delay the engine feels like it is trying to catch up to where it should be based on the amount you've already depressed the pedal, and the van starts so fast the tires are peeling out.
This doesn't happen every time, and there are times the response feels like the van is a little heavy, but the pedal is doing something and is at least a smooth acceleration if not a fast one.
Pressing the pedal hard from the get-go doesn't seem to cause the issue, so if you're cool with racecar starts out of parking lots and at left hand turns then you might not ever notice the issue, but if you're trying to cart a family and not make anyone spill their drink then it may not happen every time, but likely at least once in every trip.
The dealer updated the computer when we took the van in and complained about this the first time, and it wasn't fixed by the software update.
Happens whether the eco drive mode is engaged or not engaged.
Has not happened yet when I have the hold break mode enabled, but I haven't tested this theory long.
